Hi @Serge93 ,
I open up the .qar that you provided it seen like the previous one with verilog code
And I do not seeing any .qsys file from there, please let me know if I miss it anywhere else.
"I tried to generate a project using Platform Designer instead directly in VHDL code and I got the same error.
Then I use the https://github.com/altera-fpga/agilex5-ed-pcie-rp/releases/tag/25.1-1 project.
This project is a nightmare to just take the GTS PCIe IP.
I deleted everything except the GTS PCIe IP and finally I got the same error of bus size."
>> Is the latest project provided by you on top_stm_1d_1q_25_1_0_129.qar is the design modified from the Github design ?
Last things to clarified
This is just a part of my design, I will connect the PCIe IP in Root Port to my NVMe Host IP.
>> is the design work well ONLY with GTS Reset sequence and the PCIe IP ?
>> I think you might need to connect with the rest right ?
If you think the communication here is bit slow, we can have a Teams call , I am based in GMT +8 Time zone, we can set a time where both of us is available.
Wincent_Altera
Hello Wincent,
So, I sent you my design which is done without qsys, only with VHDL files.
I did not sent you the design from https://github.com/altera-fpga/agilex5-ed-pcie-rp/releases/tag/25.1-1 project and on which I removed nearly everything becasue this is non sens.
So, the idea is the Altera IP expert analyze my design to see what is missing to avoid the bus error.
I do not understand this questions.
The goal is to provide me an instanciation of a GTS AXI Streaming PCIe IP on AGILEX 5 I can compile without errors.
Yes we can organize a Team call, I am based in Paris, France.
I am available Thursday an Friday morning of this week.
Please send me a link.
Thanks for help.
Serge
- Wincent_Altera6 months ago
Hi Serge,
I will sent a the invitation link to you via your register email in this forum
Time will be 10AM Paris , France Time Friday.
Let me know if you did not received it. Looking forward to talk to you later.
Wincent_Altera - Wincent_Altera6 months ago
Hi @Serge93 ,
I try to build a rootport design with some IO IP attach to it to ensure that the function is well.
The compilation pass successful, I attach the .qar file there.
Please refer, if you need more time to look at that we can reschedule our meeting.
Regards,Wincent_Altera
