Yamada1
2 years agoAbout Max10 power connection
I was planning to use 10M02SCE144I7G and proceeded with reference to the Pin Connection Guidelines. was also using the circuit diagram of "EK-10M08E144" as a reference, but I noticed some differenc...
- 2 years ago
According to the Max 10 Power Management User Guide, Chapter 2.1.3,
"For Intel® MAX® 10 single-supply devices, only one power supply is required—3.0 V or 3.3 V to power the core of the FPGA. The same power supply can be used to power the I/O if the same 3.0 V or 3.3 V voltage is required. "
So it is correct that "VCC_ONE and VCCIO can be supplied from the same regulator as long as the voltage used is the same".
XY
