Hi Dimitrios.
I have since given up on VTR and Altera products altogether for my thesis. I have now switched to Xilinx. As to your question, have you come across the net2vqm tool? It doesn't convert the VTR output to sof right away, but it re-introduces Quartus back into the CAD flow. - Altera_Forum
Hello
Thank you for your quick response. Did you reached to compile a project with vpr and then go back to Quartus to generate the bitstream. I have spent lot of time searching about the structure of the sof file and now I am trying to synthesise with Odin II, optimise with ABC and place & route with VPR. The above tools are embedded in a CAD flow called VTR. Best Regards Dimitrios Agiakatsikas - Altera_Forum
I never attempted to run the entire CAD flow from HDL design to bitstream.
When I experimented with the tool, I concluded that it did not serve my purpose and so I stopped using it. VPR generates 3 files: .place for placement .route for routing .net for the final netlist after the P&R algorithm runs. There's a tool created by the EECG group at the University of Toronto which converts .net files to .vqm This tool is the nettovqm tool. (net-to-vqm) - Altera_Forum
Thanks, Socrates. Since SPI is usually msb first (http://en.wikipedia.org/wiki/serial_peripheral_interface_bus#data_transmission), does that mean the RBF file contents should go out LSB first?
--- Quote Start --- RBF is just a simple binary format, that You can upload using simple serialization mechanism (e.g. SPI: SCK->DCLK, MOSI->DATA0). Except You need to do a byte-reverse before sending. --- Quote End --- - Altera_Forum
Found the answer (http://quartushelp.altera.com/current/mergedprojects/reference/glossary/def_rbf.htm). It is LSB first.
