11 years agoRamp generation through HSMC DAC Stratix III using DSP Builder
I am able to generate proper ramp signal in DSP Builder simulink but when I program it into the FPGA, the output signal through the HSMC DAC is saturating. What is causing this and how to remove this...
11 years agoI tried for 10 kHz, the output did look like a ramp but actually that too was saturated. I could not get any solution for this. Using an analog ramp generator circuit is the only solution for now.
