11 years agoRamp generation through HSMC DAC Stratix III using DSP Builder
I am able to generate proper ramp signal in DSP Builder simulink but when I program it into the FPGA, the output signal through the HSMC DAC is saturating. What is causing this and how to remove this...
11 years agoWhat you may be seeing is the effect of that transformer - assuming you are using the Terasic ADA board, I used that in a project at Uni a couple of years ago and the transformer basically just distorted signals at both low frequencies and high frequencies.
Have you tried other waveforms and frequencies?
