11 years agoRamp generation through HSMC DAC Stratix III using DSP Builder
I am able to generate proper ramp signal in DSP Builder simulink but when I program it into the FPGA, the output signal through the HSMC DAC is saturating. What is causing this and how to remove this...
11 years ago --- Quote Start --- Is there an output transformer on the DAC? Have you checked that you are trying to output a signal within the bandwidth of any filtering on the DAC output? --- Quote End --- Yes a transformer is present. What do I need to check? Yes, the bandwidth is within the range.
