13 years agoram not working correctly
hi ..
the fpga and vhdl master ... I want to ask about the ram ... I have a little problem in the call data that are saved on ram ... when I try to testbench or i simulate in single block outgoing data is correct, but when the block I combine and i synthesis in quartus then i run in modelsim Altera with data such as skipped out .. ============================================================================== -- 2D ram subtype p_simb is std_logic_vector(7 downto 0); type t_simb is array(1 to 257) of p_simb; -- deklarasi sinyal ram signal ram_kor : t_simb; BEGIN process (rst,clk) begin if rst= '0' then << problem1 sig_pros <= '0'; Dec_codword_out <= "00000000"; cnt4wraddr <= 1; cnt4rdaddr <= 1; ram_kor <= (others=>"UUUUUUUU"); << problem2 elsif (rising_edge(clk)) then last_state <= enb_dec; last_state2 <= sig_pros; if enb_dec = '1' then cnt4wraddr <= cnt4wraddr + 1; ram_kor(cnt4wraddr) <= Dec_Din; else cnt4wraddr <= 1; end if; if (str_koreksi = '1' or str_koreksi2 = '1') then sig_pros <= '1'; elsif sig_pros = '1' then cnt4rdaddr<=cnt4rdaddr+1; if (cnt4rdaddr >= 255 ) then Dec_codword_out <= "00000000"; if (cnt4rdaddr > 255 ) then cnt4rdaddr <= 1; sig_pros <= '0'; ram_kor <= (others=>"UUUUUUUU"); << problem2 end if; end if; if (cnt4rdaddr <= 255 ) then if cnt4rdaddr = lokasi_err1 then Dec_codword_out <= ram_kor(cnt4rdaddr) xor nilai_err1; elsif cnt4rdaddr = lokasi_err2 then Dec_codword_out <= ram_kor(cnt4rdaddr) xor nilai_err2; elsif cnt4rdaddr = lokasi_err3 then Dec_codword_out <= ram_kor(cnt4rdaddr) xor nilai_err3; elsif cnt4rdaddr = lokasi_err4 then Dec_codword_out <= ram_kor(cnt4rdaddr) xor nilai_err4; elsif cnt4rdaddr = lokasi_err5 then Dec_codword_out <= ram_kor(cnt4rdaddr) xor nilai_err5; elsif cnt4rdaddr = lokasi_err6 then Dec_codword_out <= ram_kor(cnt4rdaddr) xor nilai_err6; else Dec_codword_out <= ram_kor(cnt4rdaddr); end if; end if; end if; end if; end process; koreksi_done <= '1' when (last_state2 = '1' and sig_pros = '0') else '0'; data_valid_out <= "00000000" when (cnt4rdaddr > 244 ) else Dec_codword_out; =============================================================================== the problem occurs when I add a reset, when reset I remove the program works well, but source which used to be much .... I asked how to use the ram so that I could get the data properly ..... does anyone have a solution? thanks 4 answer....2 Replies
Adding the 'reset' probably makes it use logic not memory blocks.
sory, was a little mistake...:D
when I add reset, the Data can come out correctly, but logic gate which used to be much .... and when reset I remove, ram can be realized but the Data come out incorrect ....
