Questions about RapidIO II IP core
Hello!
I am trying to use Rapidio II IP core to establish SRIO communication between FPGA and DSP. Here are some questions I have met:
Question 1
Are these signals used by users to transmit data packets?
Question 2
I notice that these signals belongs to an avalon-st sink. Should I create an avalon-st source by myself to send the data packets to him? If so, must this avalon-st source be created by Qsys or platform designer?
Question 3
The signal gen_tx_data is 128bits. Is the maximum bit width of a data packet only 128 bits?
Below is the answers for your questions:
- Yes, those are the Pass-Through Interface Signals
- The Avalon-ST pass-through interface is an optional interface that is generated when you select the Avalon-ST pass-through interface in the Transport and Maintenance page of the RapidIO II parameter editor.
- Yes, only 128 bits.
For more details, please refer to Rapid IO II UG.
Pavee
- paveetirrasrie_Altera
I’m glad that your question has been addressed, I now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
- eagles
My questions has already solved because of your answer. I've already accepted your solution.
Thank you very much!
Just wanted to check with you, is your concern has been addressed?
If yes , kindly do let me know.
Thank You
Pavee
Pavee
