11 years agoQuestions about Configuring the De5-Net FPGA Board
when i followed the steps in the "de5net_network_opencl_manual.pdf", i got the following problems: 1.in "test ‘aocl flash’ command" section, after i finished the clock setting and tried to use ...
11 years ago --- Quote Start --- After I installed the drivers successfully, I still had this problem and didn't deal with it. The errors are as followings: root@storm:/home/storm/altera/14.0/hld/board/de5net_network/tests/fft2d# aocl program acl0 bin/fft2d.aocx aocl program: Running reprogram from /home/storm/altera/14.0/hld/board/de5net_network/linux64/libexec Unable to open the device acl0. aocl program: Program failed. I appreciate someone can give me any suggestion. Best wishes, Jiawen --- Quote End --- Hi Jiawen, Did you try the aocl diagnose to make sure the system can find the fpga device currently?
