11 years agoQuestions about Configuring the De5-Net FPGA Board
when i followed the steps in the "de5net_network_opencl_manual.pdf", i got the following problems: 1.in "test ‘aocl flash’ command" section, after i finished the clock setting and tried to use ...
11 years ago --- Quote Start --- Hi B, I have deal with the problem successfully!! Thank you so much for you reply and help! Best wishes, Jiawen --- Quote End --- Hi Jiawen, For the first question, the unable to open device acl0. Can I know if you also solve that? Thanks
