11 years agoQuestions about Configuring the De5-Net FPGA Board
when i followed the steps in the "de5net_network_opencl_manual.pdf", i got the following problems: 1.in "test ‘aocl flash’ command" section, after i finished the clock setting and tried to use ...
11 years agoHi B,
After everything was setting and compile the test code of OpenCl successfully, when I tried to run the file, I got the following errors: storm@storm:~/altera/15.0/hld/board/de5net_network/tests/matrix_mult/bin$ ./matrix_mult ./matrix_mult: error while loading shared libraries: libalteracl.so: cannot open shared object file: No such file or directory Do you know what is the problem? I have followed the manual step by step to set up. Thank you, Jiawen
