11 years agoQuestions about a NIOS-II Tutorial, and how to learn NIOS
Hi all, I am a newbie to NIOS-II, and right now working on a tutorial, the link of which is listed below: https://www.altera.com/en_us/pdfs/literature/tt/tt_qsys_intro.pdf This tutori...
11 years agoFor sdram you will need something written for the exact board you are using. The settings in the memory controller block depend on the type and number of ram chips as well as the exact geometry of the traces on the board. You can't pick a random Altera tutorial unless you have the exact board the tutorial was written for. An FPGA dev board that has SDRAM on it will probably come with an example project or tutorial that uses the SDRAM.
