10 years ago
Question Regarding to the MAX V eval board.
I am new user try to run my simple test on Altera Max V eval kit. I wrote a simple code want to verify a simple function:
http://www.alteraforum.com/forum/attachment.php?attachmentid=12665&stc=1
in file counter.v
module counter( CLOCK_10KHZ, counter_out, RESET);
input CLOCK_10KHZ;
input RESET;
output  counter_out;
reg  counter_out;
always @(posedge CLOCK_10KHZ) begin
    if (!RESET)    begin        //Reset button is not pushed
        counter_out <=# 1 ~(counter_out + 1); //increment counter, neg light up the LED, and pos turn off
    end
    else begin
        counter_out <=# 1 ~16'b0;
    end
end
endmodule
When I push the reset button, the LED goes off, that proved clock trigger signal is correct, however, after I release the PB1, all LEDs still on and didn't change status(It suppose to light up and turn off while counter increasing).
Platform: Windows 7,64bit, Quartus Prime Lite Edition 16.0. MAX V Eval Board
Could anyone take a look what might be wrong with my program?
Thank you!
1 Reply
    This is not doing what you want it too and is just resulting in 'counter_out' holding a static value (both in and out of reset).
    I might suggest that you've not simulated this. Doing so would have quickly pointed out your fault.
    Firstly, remove the "#1" from your code. This means nothing to your MAX V device or any logic synthesizer.
    Secondly, change the above statement to a simple
    counter_out <= counter_out + 1;
    Then, outside of that always block, deal with the inversion that the LEDs on your hardware require.
    assign led = ~counter_out;
    Finally, swap 'led' for 'counter_out' in your module's port list.
    Cheers,
    Alex
