LBeau2
6 years agoQuestion regarding MAX10 and clock switchover
Hello, So for my product, I have already coded an SPI shift registers, then, in another module, I am comparing magnitude of 2 seperate bytes with upper and lower limit then simply output to some pin...
KhaiChein_Y_Intel
6 years agoHi,
May I know what device you are using? You may use ALTCLKCTRL for clock swicthover. ALTCLKCTRL represents clock buffers that drive the Global Clock Network, the regional Clock Network, and the dedicated External Clock Path. You can select up to 4 clock inputs.
Here is the IP user guide for reference.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altclock.pdf
LBeau2
6 years agoHello thank you so much for your response,
I am using anything from the tqfp144 10m08sce144c8g, on single supply 3.3v
Any more specific help?
A picture of the organization setup v files you would use? Example code?
