12 years agoquestion about set_input_delay and set_output_delay
Hi, My design has two FPGAs. One transmits video data to the other via bt1120 interface. I want to add "set_input_delay" and "set_output_delay" in my constraint file to ensure the data transmiss...
12 years agoOk, so let's assume zero skews and safety for simplificy.
To meet hold timing, we need a) $fpga1TcoMin >= $fpga2Th To meet setup timing, we need b) $fpga1TcoMax + $fpga2Tsu <= T Now, we need to ensure out FPGAs will actually meet those desired parameters. For the hold, we set the min input and output delays. c) We need to set $fpga1MinOutputDelay <= -$fpga1MinTco d) We need to set $fpga2MinInputDelay <= $fpga2Tsu So, putting numbers for example, we can say "2 ns". We tell the tool there's -2ns delay after FPGA1's output, so it needs to generate a design with a minTco of at least 2 ns. We tell the tool there's a 2 ns delay before FPGA2's input, so it can rely on it and it can generate a design with a Th of up to 2 ns. And if you substitute c) and d) in a), you get the condition $fpga1MinOutputDelay + $fpga2MinInputDelay <= 0 For setup, we need to set the constraints like this. e) $fpga1MaxOutputDelay >= $T - $fpga1MaxTco f) $fpga2MaxInputDelay >= $T - $fpga2Tsu To put some numbers, if we have a 20 ns T, and we split this 6/14 then we get We're telling the tool there's a 6 ns delay after FPGA1's output, so it needs to keep it's max Tco below 14 ns to meet setup timing We're telling the tool there's a 14 ns before FPGA2's input, so it needs to keep it Tsu below 6 ns to meet setup timing. And again, if we substitute e) and f) in b), we get $fpga1MaxOutputDelay + $fpga2MaxInputDelay >= T.
