17 years ago
question about sdram on nios II
After I finished my project and built it ,there is no any error or warning.But when I run my C project,it said :
"Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x00000010: verified
Initializing CPU cache (if present)
OK
Downloading 02000000 ( 0%)
Downloaded 8KB in 0.2s (40.0KB/s)
Verifying 02000000 ( 0%)
Verify failed between address 0x2000000 and 0x2001EEB
Leaving target processor paused."
I use sdram as my only storage.Is it my project so large?I hope somebody help me to solve this problem.Thanks!!
    what are the components are needed to create nios ii processor and one thing is i want to access sdram please help me i search this for last one month
    thank you
    Did you ckeck in System libraries properties that the program memory, your read_only data memory and your read_write memory were on sdram?
    have you checked the phase settings of your sdram clock ?
    there are plenty of threads on the nios forum about the sdram and nios II, what you could check.
    quartus will never give you a warning if your phase settings are not correct for your design. only if it can't archieve your timing settings ...
