17 years agoquestion about sdram on nios II
After I finished my project and built it ,there is no any error or warning.But when I run my C project,it said : "Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Processor is already...
17 years agohave you checked the phase settings of your sdram clock ?
there are plenty of threads on the nios forum about the sdram and nios II, what you could check. quartus will never give you a warning if your phase settings are not correct for your design. only if it can't archieve your timing settings ...
