RobertLiang's avatar
RobertLiang
5 years ago
Question about register's initial value
Hello, I have a question about the initial value of registers in verilog. I have heart two kinds of views. code for example: //verilog reg [7:0] test_reg = 8'b1111_0000; 1. the initial value is...
  • Hi,
    You can set the Power-Up Level option for one or more registers. If registers do not have asynchronous load capability on the chosen device, then a register that uses asynchronous clear cannot power up to High. Similarly, if registers do not have asynchronous load capability on the chosen device, then a register that uses asynchronous preset cannot power up to Low. Note that Quartus Prime Integrated Synthesis reads default values for registered signals defined in VHDL code and converts the default values into Power-Up Level settings. The software also synthesizes variables that are assigned values in Verilog HDL initial blocks into power-up conditions.
    You may refer to Chapter 1.5.1: Register Power-Up Values for details
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-design-recommendations.pdf
    KhaiY
