14 years agoquestion about propagation delay of basic logical gates in IC
Hi guys,
Is anybody know the delay for AND2, OR2, NOT and D flip-flop based on the popular fabrication technique? and suppose the delay for an AND2 gate is unit 1, what about the delay for AND3 or AND4 under the same fabrication? I am talking about the propagation delays of gates within an IC.Thanks.2 Replies
For FPGAs the delays for simple functions (ones that fit into a lookup table) should be similar. For example AND2 and OR2 fit within a single LUT and so the delay should be the same. The delay for AND3 and AND4 will be the same as AND2 because those functions (3 and 4 input) still fit within a LUT. The total delay is a result of the place and route too so there is no simple answer for that one.
--- Quote Start --- Hi guys, Is anybody know the delay for AND2, OR2, NOT and D flip-flop based on the popular fabrication technique? and suppose the delay for an AND2 gate is unit 1, what about the delay for AND3 or AND4 under the same fabrication? I am talking about the propagation delays of gates within an IC.Thanks. --- Quote End --- The question has a different answer for every different type of technology. - The answer for a CPLD will be different than the answer for an FPGA which will be different than the answer for an ASIC - For a given technology, the answers can vary for different suppliers. For a given technology, the answer can vary by the process used by the same supplier to produce different generations of product Kevin Jennings
