15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years agowhat do you mean by "if your design treats it asynchronously" ?
"you might have two 10ns clocks with data going between them through an asynchronous FIFO. That would allow you to cut timing between them" [now if I set false path between the two clocks then about about other places where these two clocks are used ? (I am not able to visualize the problem) can you explain "Obviously if the clocks are truly asynchronous, there is no way to pass data synchronously"
