15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years agoSo, "set_multicycle_path" is not a "timing relaxation tool" and should be only used if the design actually has multicycle setup right?.
And if a Path has two cloks of different frequencies [if this difference is INTEGER multiple then it becomes "multicycle" right?] then i can consider these clocks a asynchronous and i can either set this path is "false path" or " separate those two clocks using "set_clock_group -asynchronous" [each clock will be in different groups] right? Thanks, AA
