15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years agoI looked at my private sent message. I said Zero, but I did send you one message, So I am posting it here again since I was not sure whether you had actually received the message.
My message: I used Timing Optimization Advisor[TOA] to tweak my design. The results were not consistent. [some times the teaks seems to work and some times it doesn't. Some times there are variations in the normal cases[with no tweaks] that outperforms the cases with tweaks] Here are my observations: observation 1: Some of the settings after following the TOA suggestions looked like this: restructure multiplexers: OFF state machine encoding: One Hot smart compilation: ON. In spite of this the Fmax did not exceed one of the cases when I hadn't followed the TOA suggestions. observation 2: The compilation time did not change after switching the "Smart Compilation" option to ON. But in one case it reduced from 12min to 8 min. Are these options reliable? Looks like the randomness that occurs during the compilation is very dominant. Am I doing something wrong? Thanks, AA
