15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years ago --- Quote Start --- a) In the Qsys generation tab select the "Standard, BFMs for standard Avalon Interfaces" and the qsys will attach appropriate BFM's to the PCIe IP. --- Quote End --- Unless Qsys gives you the option of adding a PCIe BFM, then this is of no interest to you (just yet). Go and complete the PCIe reference design first. That should give you a better understanding. Look where they connect their PCIe BFM; its probably outside the Qsys system. Cheers, Dave
