15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years ago --- Quote Start --- I kind of understand what you are talking about, but I haven't understood things as deeply as you have. I want to understand things in depth, its more fun. --- Quote End --- My comments should be taken as encouragement to learn more. The Altera webinars are pretty good, so go and look at their online training and listen to a few of them. --- Quote Start --- In your design you have two PCIe IPs. How do you connect those IP's, I connected the conduits together. I get errors. --- Quote End --- The PCIe IPs should be connected exactly as you would on a PCB. The SERDES links would connect as; root_tx => endpoint_rx, and root_rx <= endpoint_tx. What other signals are there? Cheers, Dave
