15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years agoget a simple pci to memory example working
Using PCI and PCIe I have written data to the memory in SOPC. and I have implemented the same system in Qsys using PCIe [I basically modified the mstr_tranx.v file generated the SOPC/Qsys system to read and write data to the RAM] . Is this understand sufficent to before I get on to modify the core components [_hw.tcl]? and then once you are sure you understand how to configure the pci core correctly, create your own _hw.tcl file for qsys. Where can I find the _hw.tcl file for PCI IP, I could not find it. I actually haven't tried creating a new component, and haven't modified _hw.tcl filie. Will work on it and will get back if I have questions. Any suggestions before I try to create new components? Thanks a lot, your quick replies are very much appreciated Aditya
