15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years ago --- Quote Start --- when I create a variation of the component using Megafunction. Can I make the new component to show up in the IP list? --- Quote End --- Megafunctions and Qsys are different tools. Not all Megafunctions have Avalon interfaces, so they cannot be used within Qsys without first creating a custom Avalon-MM or ST interface. If you used generics in your Qsys definition of the component interface, you could then pass those down to the Megafunction component. Is that what you were asking? Cheers, Dave
