15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years agoHey Dave,
When I try to import an older system into Qsys I get the following errors and doubts: errors: 1. component xxx must have an associated reset. [i edited the pins and got rid of the error for one of the simple design.]. does qsys create a global reset pin ? [ i get this for all the components] 2. it says asks me to replace pci-compiler with a compatible component. doubts a. Why does it not complain about not finding the PCI-compiler IP in it's IP list? b.Automatically coundits show up in all the components [What are they?(i read the manual, but not satisfied with explanation) and why are they created]. I Igonered the conduits in one of my designs: the simulation worked fine and I could also run the "compile Design without any errors" c. Instead of creating the new system with PCIe, can I use the MegaIP wizard to modify the PCI-compiler and then add it to my Qsys system. [Any component is related with only two files right?; its verilog file and _hw.tcl file] Thanks and have a joyous day, Aditya
