15 years agoQuestion about Internal Memory configuration
Hi all. I am trying to implment a Dual port RAM using CycloneIII EP3C10. As listed by the handbook, EP3C10 has 46 M9K Blocks. I want to configure the memory as 5120 × 32bit. MegaWizard tell me the me...
15 years agoThe megawizard isn't able to optimize the use of memory blocks when the size isn't a power of two. To reduce the blocs usage you must create two memories, one 4096*32 and one 1024*32, and add some logic to select which block to use.
