12 years agoQuestion about editing components in qsys
I've got a custom component in a qsys project. I'm wondering every time when I modify the source file, do I have to delete the component from the 'system contents', edit the component, save and re-add the component back to the 'system contents'? Is there anyway I can refresh/update the component already connected in the 'system content'? Thank you guys.2 Replies
No you don't need to delete and edit component every time you made changes in source file.You need to edit the component only if you are changing the top level I/O Ports.Even it is not require to generate qsys system if you are changing source code from synthesis/submodules directory.In this case you just need to compile the design.
File -> Refresh System works for me. No need to delete the component. Thanks, Evgeni https://www.alteraforum.com/forum/attachment.php?attachmentid=8170
