RLee42
5 years agoquestion about dual-purpose pins used as normal I/O
I'm using 10M08SAE144I7 for the new design. Since the normal IO number is not enough for this design, in order to add more IO, I disable all the dual-purpose pins in the device by unticking all the o...
RLee42
5 years agoThank you for your reply.
I've already hard-wired the nCONFIG, CONF_DONE pins to control other components as the output pins, and the nSTATUS pin as GPIO connecting with another MCU. They are already used as the user I/O on the PCB so I think that option may conflict with the hardware.
However, I've made an experiment that I jumped wire the nCONFIG, CONF_DONE to 3.3v through 10k resistor, then the FPGA can run successfully after reboot. I think these two pins should better be left alone and pull-up for the next version.
AminT_Intel
5 years agoHello,
Thank you for sharing!
