17 years agoQuestion about Clock Crossing Bridge
Hi,All
I have tried to use the clock crossing bridge to save the area to improve my design.I think when i use the clock crossing bridge ,the CDC module will be instead.But,after i compile the SOPC i find the CDC is still there.Would you please to tell me what should i if i want to get rid of the CDC module.(I use Quartus7.2SP2). Thanks a lot!4 Replies
If you can post an image of your SoPC system, I can tell you where your getting clock crossing issues. Or you can send me your project.
Jake - Altera_Forum
I set the clocks just like you said.After i compiled the project,there are lots of clock module.Does it mean that the CDC module has been inserted? Or i have misunderstood it? - Altera_Forum
Did you set the correct clocks on the two sides of the clock crossing bridge? The slave side should be the same clock as all masters connected to it. Likewise the master side should be the same clock as all it's slaves.
Jake
