17 years agoQuestion about Clock Crossing Bridge
Hi,All I have tried to use the clock crossing bridge to save the area to improve my design.I think when i use the clock crossing bridge ,the CDC module will be instead.But,after i compile the ...
17 years agoDid you set the correct clocks on the two sides of the clock crossing bridge? The slave side should be the same clock as all masters connected to it. Likewise the master side should be the same clock as all it's slaves.
Jake
