Questa showing red signal when both signals from an AND operation are high
The w_en signal is not going high, it is going to undefined.
I suspect there are other driver(s) that also assign to w_en that are driving low.
When you drive both high and low you get an undefined, which is what you are seeing in the red trace.
That's the first thing I checked. I didn't mentioned this but I have simulated the Hyperbus controller IP by itself in Questa and it doesn't have this issue. It's only a problem when a simulate it with the entire platform designer system using the generated testbench. I have verified that there is nothing different in the verilog file containing the w_en signal in the generated testbench.
- Kevin262 years ago
Never mind, I was looking at the wrong AXI verilog file. There was another file with a very similiar name that also had a w_en signal. Thanks for your help.
