XQSHEN's avatar
XQSHEN
4 years ago
Quesiton for Cyclone IV design
Device: EP4CE15M9I7N
1) Bank 3 & 4 are used for DDR2 RAM. In each bank, there are two reference pin VREFB3N0 & VREFB3N1. Just confirm only one pin should be used as reference, the other one can be used as general IO, right ?
2) In the pin out list, there is dedicated pin for DDR2 DQS and CLK. Just confirm any diferential IO at banck 3 & 4 can be used for DDR2 DQS and CLK, right?
3) There are two pins for DM: DM5B0 & DM5B1. As I used 16 bit DDR2, should I assign LDM = DM5B0 or DM5B1?
4) I use high speed ADC with LVDS output based on power supply = 1.8V. But intel sepc requires FPGA LVDS IO VCCIO = 2.5V. Can connect it drectly? DC couple?
5) Configuration device EPCQ-A will replace old device EPCS16, right?
6) MSEL0, MSEL1.... requires related VCCIO = 3.3V, right? So bank 2 VCCIO = 3.3V?
7) Bead is used for separate VCC_PLL and VCCINT. How to select bead? Which impedance @ requency should be taken into account when choose bead?
What's max power current for power supply VCCINT, VCCIO, VCCA, VCC_PLL? Can I get this value from datasheet before doing any power analysis job for choose power supply?
  • Ash_R_Altera's avatar
    Ash_R_Altera
    This thread will now be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
    Ash_R_Altera
    Sorry I didn't see the responses to the questions. Adding my 2nd level responses below:
    Answer -> Yes, one pin can be used as general IO. The usage depends upon which VREF group you are using.
    XSHEN -> What do mean depends on VREF group? I think you are talking about VREF is referred to its bank, right?
    Answer 2 -> There are two groups of pins in each bank with a corresponding VREF. If a group is not assigned a voltage-referenced IO standard, corresponding VREF can be used as general IO.
    and CLK, right?
    Answer -> Though the dedicated DQS pin is optional to use, please note that this pin drive the dedicated phase shift ciruitry which helps in fine tuning of the input strobe.
    XSHEN -> I did not get the answer. My question is that any specified pin for DQS and CLK from FPGA side?
    Answer 2 -> Yes, there are dedicated CLK and DQS pins available.
    Answer -> Any pin can be used. Base it on the corresponding data byte placement.
    XSHEN -> OK
    drectly? DC couple?
    Answer -> Please refer to this KDB article: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/soluti...
    XSHEN -> OK, so the answer is yes.
    Answer -> Yes. Refer Figure 1 in the following link: https://www.intel.com/content/www/us/en/programmable/documentation/tfb1498107381358.html?wapkw=EPCS1...
    XSHEN -> OK
    VCCIO = 3.3V?
    Answer -> MSEL pins should be connected to VCCA. The value of VCCA = 2.5V.
    XSHEN - > OK. Can I assign bank 6 VCCIO = 1.8V and CONF_DONE pulled up to 1.8V ?
    Answer 2 -> Yes.
    bead?
    Answer -> Refer Pin connection guideline, footnote 8:
    (8) Use separate power island for VCCA and VCCD_PLL. PLL power supply may originate from another plane on the board but must be isolated using a ferrite bead or other equivalent methods. If using a ferrite bead, choose an 0402 package with low DC resistance, higher current rating than the maximum steady state
    current for the supply it is connected to(VCCA or VCCD_PLL) and high impedance at 100 MHz.
    XSHEN -> OK.
    Answer -> Use Early Power Estimator (EPE) tool to estimate the power. For more details and links, refer:
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-iv/cyclone4-hand...
    XQSHEN - > I know EPE tools. But the marco in excel is too old to pen. It doesn't work and will stuck computer.
  • XQSHEN's avatar
    XQSHEN
    and CLK, right?
    XSHEN -> OK
    drectly? DC couple?
    XSHEN -> OK
    VCCIO = 3.3V?
    bead?
    XSHEN -> OK.
    Ash_R_Altera
    Please find the answers inline:
    and CLK, right?
    drectly? DC couple?
    Answer -> Please refer to this KDB article: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd04282010_33.html
    Answer -> Yes. Refer Figure 1 in the following link: https://www.intel.com/content/www/us/en/programmable/documentation/tfb1498107381358.html?wapkw=EPCS16%20migration#abq1501510072493
    VCCIO = 3.3V?
    bead?
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-iv/cyclone4-handbook.pdf#page=462
