17 years agoQuartus8.1 Memory Initialization File Warning
I have made a ROM and its memory Initialization file:Hexadecimal (Intel-Format) File in my project, when I complied my design , there has a critical warning:Can't read Memory Initialization File or H...
17 years agoright,
each time the megawizzard is finished, the files are overwritten. thats why i set the file attributes for the memory initialisation files to write protect. so if you set this attribut, you can run the wizzard and compile the project. if you regenerate the memory initialisation file *hex or *.mif then do not forget to set the attribut again. for me this helps.
