17 years agoQuartus8.1 Memory Initialization File Warning
I have made a ROM and its memory Initialization file:Hexadecimal (Intel-Format) File in my project, when I complied my design , there has a critical warning:Can't read Memory Initialization File or H...
17 years agoDear senlin,
as MSchmitt already mentioned, there is a problem with the MegaWizard that overwrites your .hex or .mif files. So to solve the problem you could try to generate your ROM1 module with the MegaWizard. The MegaWizard will generate (and overwrite your previous!) ROM1.hex file. You can now copy your own ROM1.hex file over the generated ROM1.hex file. Hope this helps! 祝福!
