8 years ago
Quartus13.1 Fatal Error, when generate .sof
I compile the project, the quartus shows it already pass synthesis and fitter successfully,
the error shows when generate programming files, error message is show as follow:
the quartus versions I use is 13.1 and FPGA is 5CGXFC7D6
https://alteraforum.com/forum/attachment.php?attachmentid=15088&stc=1
https://alteraforum.com/forum/attachment.php?attachmentid=15089&stc=1
anyone knows what's the reason cause this problem and how to solve it?
Thanks in advance.
Qi
    Try deleting the db and incremental_db directories and then recompiling. Something could just be corrupted.
    this project is:
    1. transmit 8 channels lvds signals (200M) out to daugther board, use ALTLVDS_TX ipcore;
    2. receive 8 channels lvds signals (200M) in from daugther board, use oversampling logic;
    3. collecting 8 channels data and transmit to PC by cameralink;
    4. other modules all some data processing;
    is this enough?
    Can you tell about your design?
    The error may be because of logical issues.
    Or
    Try a different version of Quartus.
    Anand Raj Shankar
