quartus_sh --simlib_comp is adding -dbg compile option
Is there a way to compile the libraries without the "-dbg" option added to the scripts ?
Christophe
- RichardT_altera
As there is solution to this issue, I now transition this thread to community support.
Richard Tan
- cdesmouliers
Hello Richard,
Thanks for looking into it.
Is there a way to generate only the compilation scripts for the Intel libraries ?
Christophe
- RichardT_altera
As of now, we do not have the flexibility to exclude -dbg from the script.
You will need to get the precompiled library without the -dbg option from the Aldec.
Richard Tan
- RichardT_altera
I yet to receive response from the engineering team. I will follow up with them.
- RichardT_altera
Let me check this with the engineering team. See if there is a way to exclude the -dbg option.
Richard Tan
- cdesmouliers
We noticed that when we started doing coverage.
Coverage data are picked up for all intel components which is not what we want.
Also, the -dbg compile option prevents from some optimizations.
Aldec provides precompiled library without the -dbg option but I wanted to know if there is a way to recompile on our side without this.
Christophe
- RichardT_altera
May I understand is there an issue with the -dbg compile option?
As of now, I don't think there is an option to turn off the -dbg option as the command script was wrote by the engineering team years ago.
Richard Tan
- cdesmouliers
I know there is no -dbg option to the command line.
What I am saying is that the resulting compiled libraries are compiled with the -dbg option for Riviera Pro.
I am asking if there is a way to tell to quartus_sh not to compile those with -dbg. Also is there a reason why it was done this way.
Christophe
- RichardT_altera
You may checkout this page on the correct way in Using EDA Simulation Library Compiler in the Command Line:
There is no -dbg option required in the cmd line so you can exclude it.
Richard Tan
