Quartus Pro an Lite different handling of VHDL entities problem
I've been developing a design in VHDL under Quartus 20.1 Lite and the time has come to migrate it to Quartus 23.1 Prime Pro. It's giving me a real headache because Pro is choking on stuff that compiled fine under Lite.
A typical error is:
Error(13780): VHDL error at DAC8564IFBasic.vhd(53): type of identifier "spi_master_writeonly" does not agree with its usage as "component" type
The source line is:
rsm: work.spi_master_writeonly generic map (.....) port map(....)
I still feel like quite a VHDL newbie, so I'm stumped.
Have to use something like below:
rsm: entity work.spi_master_writeonly generic map (.....) port map(....)
Also can do like below as well:
use work.spi_master_writeonly;
rsm: spi_master_writeonly generic map (.....) port map(....)
Pro version is more strict compared to Lite version.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer.
- ShengN_altera
FYI. The synthesis engine used for both Pro and Standard/Lite version are different. Pro version uses Qsyn synthesis engine while Standard/Lite version uses Qmap synthesis engine.
May checkout this link https://www.intel.com/content/www/us/en/docs/programmable/683463/23-3/upgrade-non-compliant-design-rtl.html under section Migrating to Intel® Quartus® Prime Pro Edition for more information:
The quartus_syn synthesis enforces stricter industry-standard HDL structures. Stricter syntax/semantics check for improved compatibility with other EDA tools. The Compiler generates errors when processing non-compliant RTL.
Sheng
- ShengN_altera
Sheng
- Oliver_I_Sedlacek
Contributor
Thanks for that. I don't suppose there's a document that lists these differences in strictness, as I'm seeing other problems?
Not being a VHDL guru I'm surprised that these differences are allowed in the language specification.
