Seadog's avatar
Seadog
7 years ago
Quartus Prime Pro crash-prone
I keep getting this unwanted message:
I am running QPP 18.1 Build 222 09/21/2018 SJ Pro Edition, on windows 10. The crashes seem to occur most frequently when I am running Timing Analyzer.
  • Seadog's avatar
    Seadog
    Vicky,
    I have not solved the issue. I have tried QPP 19.2, and it also has crashed in a similar manner. In this case, I was cross-probing from Timing Analyzer to Chip Planner (Locate Path-> Locate in Chip Planner).
    I can delete the compiler output, but then I do do another build, which can take a couple of hours; so I am disinclined to do that very often.
  • Vicky1's avatar
    Vicky1
    Have you resolved the issue?
    May I know any update?
    Vicky
  • Vicky1's avatar
    Vicky1
    "I keep getting this unwanted message:" please provide here the errors/ messages you observed.
    In addition, Close the Quartus tool, delete the 'db' & 'incremental_db' folder from project directory then try to recompile & run timing analyzer.
    Try to check at your end by creating new fresh project using these files.
    Check the Quartus 18.1.2 updates from the 'Updates' tab from link below,
    http://fpgasoftware.intel.com/18.1/?edition=pro
    Vicky
  • AndyN's avatar
    AndyN
    Try doing a Clean Project, then delete the qdb, output_files, and temp-clearbox folders. That usually does the trick...
