Quartus Prime Pro crash-prone
I keep getting this unwanted message:
I am running QPP 18.1 Build 222 09/21/2018 SJ Pro Edition, on windows 10. The crashes seem to occur most frequently when I am running Timing Analyzer.
- AndyN
Try doing a Clean Project, then delete the qdb, output_files, and temp-clearbox folders. That usually does the trick...
- Vicky1
"I keep getting this unwanted message:" please provide here the errors/ messages you observed.
In addition, Close the Quartus tool, delete the 'db' & 'incremental_db' folder from project directory then try to recompile & run timing analyzer.
Try to check at your end by creating new fresh project using these files.
Check the Quartus 18.1.2 updates from the 'Updates' tab from link below,
http://fpgasoftware.intel.com/18.1/?edition=pro
Vicky
- Vicky1
Have you resolved the issue?
May I know any update?
Vicky
- Seadog
Vicky,
I have not solved the issue. I have tried QPP 19.2, and it also has crashed in a similar manner. In this case, I was cross-probing from Timing Analyzer to Chip Planner (Locate Path-> Locate in Chip Planner).
I can delete the compiler output, but then I do do another build, which can take a couple of hours; so I am disinclined to do that very often.
- Vicky1
"I keep getting this unwanted message:" please provide here the errors/ messages you observed. -------------- if you are able to reproduce please provide that message & screenshot.
'I have not solved the issue. I have tried QPP 19.2, and it also has crashed in a similar manner.' ---- what do you mean crashed ? what you observed exactly?
you can also check by fresh downloading & installing again Quartus prime pro 19.2, it might get corrupted the setup while downloading.
Vicky
- Seadog
Here is a fresh dump from 18.1 Standard:
Problem Details
Error:
*** Fatal Error: Access Violation at 0X00007FF97361C778
Module: quartus.exe
Stack Trace:
0x6c777: ACVQM_OBJECT_INTERFACE::is_underlying_object_valid + 0xe7 (ACE_ACVQ_ACVQM)
0x2d25b: ACVQM_MAPPER::update_given_matrix + 0xcb (ACE_ACVQ_ACVQM)
0x9322f: ACVQM_OBJECT_GROUPING_MANAGER::modify_mapper_with_sets + 0x3ef (ACE_ACVQ_ACVQM)
0x9366e: ACVQM_OBJECT_GROUPING_MANAGER::modify_overlay_set + 0x12e (ACE_ACVQ_ACVQM)
0x8469f: ACVQM_COMMAND_MANAGER::highlight + 0x7f (ACE_ACVQ_ACVQM)
0x4ebbb: acvqc_highlight + 0x9b (ace_acvq_acvqc)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x17a65: TclEvalEx + 0xa65 (tcl86)
0x18257: Tcl_Eval + 0x37 (tcl86)
0x105e7: atcl_tcl_eval + 0x117 (ccl_atcl)
0x58cbb: ACVQV_LOCATE_HISTORY_VIEW::process_highlight + 0x35b (ACE_ACVQ_ACVQV)
0x517e5: ACVQV_LOCATE_HISTORY_VIEW::qt_static_metacall + 0x165 (ACE_ACVQ_ACVQV)
0x11c420: QMetaObject::activate + 0x520 (QtCore4)
0x160ff9: QAbstractItemModel::dataChanged + 0x39 (QtCore4)
0x4eb2c1: QStandardItemModel::itemChanged + 0x131 (QtGui4)
0x4ed588: QStandardItem::setData + 0x178 (QtGui4)
0x4ed5ea: QStandardItemModel::setData + 0x3a (QtGui4)
0x4f9c73: QStyledItemDelegate::editorEvent + 0x223 (QtGui4)
0x472579: QAbstractItemView::selectionModel + 0x109 (QtGui4)
0x46c0f2: QAbstractItemView::edit + 0xf2 (QtGui4)
0x46fd13: QAbstractItemView::mouseReleaseEvent + 0x183 (QtGui4)
0x4a5d09: QTreeView::mouseReleaseEvent + 0x39 (QtGui4)
0xbd835: AFCQ_TREE_VIEW::mouseReleaseEvent + 0x365 (GCL_AFCQ)
0x60794: QWidget::event + 0xd4 (QtGui4)
0x382676: QFrame::event + 0x36 (QtGui4)
0x47552c: QAbstractItemView::viewportEvent + 0x4ac (QtGui4)
0xc1656: AFCQ_TREE_VIEW::viewportEvent + 0x2b6 (GCL_AFCQ)
0x10f802: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0x82 (QtCore4)
0x22e81: QApplicationPrivate::notify_helper + 0xe1 (QtGui4)
0x21a8e: QApplication::notify + 0x71e (QtGui4)
0x10d92b: QCoreApplication::notifyInternal + 0x7b (QtCore4)
0x25cfe: QApplicationPrivate::sendMouseEvent + 0x1de (QtGui4)
0x856f0: QScrollBar::trUtf8 + 0x1440 (QtGui4)
0x890b1: QApplication::winMouseButtonUp + 0x2761 (QtGui4)
0xca65: DispatchMessageW + 0x6a5 (USER32)
0xc581: DispatchMessageW + 0x1c1 (USER32)
0x132802: QEventDispatcherWin32::processEvents + 0x3e2 (QtCore4)
0x80eb4: QApplicationPrivate::openPopup + 0x204 (QtGui4)
0x10a88b: QEventLoop::exec + 0x22b (QtCore4)
0x10ce6f: QCoreApplication::exec + 0xdf (QtCore4)
0x197b: qgq_main + 0x7b (quartus)
0x12e98: msg_main_thread + 0x18 (CCL_MSG)
0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16660: mem_thread_wrapper + 0x70 (ccl_mem)
0x12761: msg_exe_main + 0xa1 (CCL_MSG)
0x24e7: WinMain + 0x127 (quartus)
0x1e58: __tmainCRTStartup + 0x148 (quartus)
0x17973: BaseThreadInitThunk + 0x13 (KERNEL32)
0x6a270: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 18.1.0
Build: 625
Edition: Standard Edition
- Vicky1
Thanks for the update.
it seems to be a bug but I`m not sure, Could you please provide the project (*.qar)file (Project Menu-> Archive Project...) for replication purpose?
Vicky
- Seadog
I can't post a design to the forum, no.
- Vicky1
Hello Daniel,
I checked in knowledge database, I couldn`t find the any entry for Quartus crashes by running the timing analyzer.
we(Intel support team) are checking internally so once I got any update I`ll update you.
Thanks for your cooperation & patience.
Vicky
- Seadog
Vicky,
Here is another crash dump, this time from QPP 18.1; this occurred while I was cross-probing from Timing Analyzer to Chip Planner:
Problem Details
Error:
*** Fatal Error: Access Violation at 00007FF984EB0B90
Module: qpro.exe
Stack Trace:
0x70b8f: ACVQM_OBJECT_INTERFACE::is_underlying_object_valid + 0xdf (ACE_ACVQ_ACVQM)
0x2947b: ACVQM_MAPPER::update_given_matrix + 0xcb (ACE_ACVQ_ACVQM)
0x98d11: ACVQM_OBJECT_GROUPING_MANAGER::modify_mapper_with_sets + 0x3f1 (ACE_ACVQ_ACVQM)
0x990fe: ACVQM_OBJECT_GROUPING_MANAGER::modify_overlay_set + 0x12e (ACE_ACVQ_ACVQM)
0x8a2ef: ACVQM_COMMAND_MANAGER::highlight + 0x7f (ACE_ACVQ_ACVQM)
0x3f9db: acvqc_highlight + 0x9b (ace_acvq_acvqc)
0x16442: TclNRRunCallbacks + 0x62 (tcl86)
0x17c4d: TclEvalEx + 0x9ed (tcl86)
0x18437: Tcl_Eval + 0x37 (tcl86)
0x11555: atcl_tcl_eval + 0x125 (ccl_atcl)
0x5a993: ACVQV_LOCATE_HISTORY_VIEW::process_highlight + 0x333 (ACE_ACVQ_ACVQV)
0x55ed2: ACVQV_LOCATE_HISTORY_VIEW::dataChanged + 0x52 (ACE_ACVQ_ACVQV)
0x5b558: ACVQV_LOCATE_HISTORY_VIEW::qt_static_metacall + 0xe8 (ACE_ACVQ_ACVQV)
0x1de156: QMetaObject::activate + 0x576 (Qt5Core)
0x180c8e: QAbstractItemModel::dataChanged + 0x3e (Qt5Core)
0x29c8b8: QStandardItemModel::itemChanged + 0x1d8 (Qt5Gui)
0x29eefb: QStandardItem::setData + 0x31b (Qt5Gui)
0x29ef9a: QStandardItemModel::setData + 0x3a (Qt5Gui)
0x2516fd: QStyledItemDelegate::editorEvent + 0x25d (Qt5Widgets)
0x23897c: QAbstractItemView::selectionModel + 0x19c (Qt5Widgets)
0x231e86: QAbstractItemView::edit + 0xd6 (Qt5Widgets)
0x235f3f: QAbstractItemView::mouseReleaseEvent + 0x16f (Qt5Widgets)
0xb8d04: AFCQ_TREE_VIEW::mouseReleaseEvent + 0x364 (GCL_AFCQ)
0x3a66b: QWidget::event + 0xdb (Qt5Widgets)
0xdb006: QFrame::event + 0x36 (Qt5Widgets)
0x23bfe8: QAbstractItemView::viewportEvent + 0x318 (Qt5Widgets)
0xbc578: AFCQ_TREE_VIEW::viewportEvent + 0x2a8 (GCL_AFCQ)
0x1c0e8c: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0xdc (Qt5Core)
0x18d7b: QApplicationPrivate::notify_helper + 0x12b (Qt5Widgets)
0x1699c: QApplication::notify + 0x8dc (Qt5Widgets)
0x1beab8: QCoreApplication::notifyInternal2 + 0xb8 (Qt5Core)
0x1a0d5: QApplicationPrivate::sendMouseEvent + 0x325 (Qt5Widgets)
0x62898: QSizePolicy::QSizePolicy + 0x2d18 (Qt5Widgets)
0x6060d: QSizePolicy::QSizePolicy + 0xa8d (Qt5Widgets)
0x18d8f: QApplicationPrivate::notify_helper + 0x13f (Qt5Widgets)
0x17c16: QApplication::notify + 0x1b56 (Qt5Widgets)
0x4cc00: QGuiApplicationPrivate::processMouseEvent + 0x870 (Qt5Gui)
0x345fa: QWindowSystemInterface::sendWindowSystemEvents + 0x9a (Qt5Gui)
0x2084e4: QEventDispatcherWin32::processEvents + 0xd64 (Qt5Core)
0x207cb5: QEventDispatcherWin32::processEvents + 0x535 (Qt5Core)
0x4ff88: qt_plugin_query_metadata + 0x1d18 (qwindows)
0x1ba982: QEventLoop::exec + 0x1b2 (Qt5Core)
0x1bd713: QCoreApplication::exec + 0x143 (Qt5Core)
0x10bb: qgq_main + 0x8b (qpro)
0x13e58: msg_main_thread + 0x18 (CCL_MSG)
0x1516e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x1f900: mem_thread_wrapper + 0x70 (ccl_mem)
0x1348e: msg_exe_main + 0xae (CCL_MSG)
0x20c3: WinMain + 0x153 (qpro)
0x16d2: __scrt_common_main_seh + 0x116 (qpro)
End-trace
Executable: qpro
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Address bits: 64
Version: 18.1.0
Build: 222
Edition: Pro Edition
