Quartus Prime Lite 23.1std crashes on elaboration of a register file
When synthesizing a project in Quartus with a memory element, it crashes during the MEM entity elaboration, yielding the following error:
Problem Details
Error:
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/vhdl/vhdlvalue_elab.cpp, Line: 3865
_values && pos < _values->Size()
Stack Trace:
0x118e06: vrfx_find_file(char const*, char const*, char const*) (synth_vrfx)
0x2bd6ed: VhdlCompositeValue::SetValueAt(unsigned int, VhdlValue*) + 0x53 (synth_vrfx)
0x2ef1d8: VhdlIdRef::AssignPartial(VhdlValue*, VhdlConstraint*, VhdlValue*, VhdlValue*, Net*, Array const*, unsigned int, VhdlDataFlow*) + 0x59e (synth_vrfx)
0x2e873f: VhdlIdRef::Assign(VhdlValue*, VhdlDataFlow*, Array*) + 0xfb (synth_vrfx)
0x2ead2e: VhdlIndexedName::Assign(VhdlValue*, VhdlDataFlow*, Array*) + 0xbe (synth_vrfx)
0x30eaf2: VhdlSignalAssignmentStatement::Execute(VhdlDataFlow*, VhdlBlockConfiguration*) + 0x1ac (synth_vrfx)
0x31573a: VhdlIfStatement::Execute(VhdlDataFlow*, VhdlBlockConfiguration*) + 0x5d6 (synth_vrfx)
0x314c9d: VhdlProcessStatement::Execute(VhdlDataFlow*, VhdlBlockConfiguration*) + 0x1e9 (synth_vrfx)
0x2b36f2: VhdlArchitectureBody::Elaborate(VhdlBlockConfiguration*) + 0x122 (synth_vrfx)
0x2b4130: VhdlEntityDecl::CoreElaborate(VhdlSecondaryUnit*, char const*, VhdlBlockConfiguration*) + 0x44e (synth_vrfx)
0x2b9982: VhdlEntityDecl::Elaborate(char const*, Array*, Map*, VhdlBlockConfiguration*) + 0x3f2 (synth_vrfx)
0x13d179: VRFX_VERIFIC_VHDL_ELABORATOR::elaborate(BASEX_ELABORATE_INFO*) + 0x1fb (synth_vrfx)
0x132888: VRFX_ELABORATOR::elaborate(BASEX_ELABORATE_INFO*) + 0xc8 (synth_vrfx)
0x1b9a03: SGN_FN_LIB::elaborate(BASEX_ELAB_INFO_CORE*) const + 0x193 (synth_sgn)
0x1c34ce: SGN_FN_LIB::start_vrf_flow() const + 0xe (synth_sgn)
0x1c3cd0: SGN_FN_LIB::start(SGN_WRAPPER_INFO*) + 0x720 (synth_sgn)
0x1c843a: SGN_EXTRACTOR::single_module_extraction(HDB_INSTANCE_NAME*, HDB_ENTITY*, SGN_WRAPPER_INFO*) const + 0x10a (synth_sgn)
0x1d02be: SGN_EXTRACTOR::recursive_extraction(HDB_INSTANCE_NAME*, SGN_WRAPPER_INFO*, char const*) + 0x14e (synth_sgn)
0x1d147f: SGN_EXTRACTOR::recurse_into_newly_extracted_netlist(HDB_ENTITY*, HDB_INSTANCE_NAME*, unsigned long, SGN_WRAPPER_INFO*) + 0x55f (synth_sgn)
0x1d047c: SGN_EXTRACTOR::recursive_extraction(HDB_INSTANCE_NAME*, SGN_WRAPPER_INFO*, char const*) + 0x30c (synth_sgn)
0x1dc6f3: SGN_EXTRACTOR::extract() + 0x363 (synth_sgn)
0x1e8362: sgn_qic_full(CMP_FACADE*, std::vector<std::string, std::allocator<std::string> >&, std::vector<double, std::allocator<double> >&) + 0x2a2 (synth_sgn)
0x209eb: qsyn_execute_sgn(CMP_FACADE*, std::vector<std::string, std::allocator<std::string> >&, std::string const&, THR_NAMED_PIPE*, THR_NAMED_PIPE*) + 0x22b (quartus_map)
0x3b0c6: QSYN_FRAMEWORK::execute_core(THR_NAMED_PIPE*, THR_NAMED_PIPE*) + 0x296 (quartus_map)
0x3eeb2: QSYN_FRAMEWORK::execute() + 0x1b52 (quartus_map)
0x1ddd9: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x881 (comp_qexe)
0x3200e: qsyn_main(int, char const**) + 0x14e (quartus_map)
0x3e5c0: msg_main_thread(void*) + 0x10 (ccl_msg)
0x5c9c: thr_final_wrapper + 0xc (ccl_thr)
0x3e68a: msg_thread_wrapper(void* (*)(void*), void*) + 0x6e (ccl_msg)
0xc096: mem_thread_wrapper(void* (*)(void*), void*) + 0x96 (ccl_mem)
0x91a8: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x5cdf: thr_thread_wrapper + 0x15 (ccl_thr)
0x4058a: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xa8 (ccl_msg)
0x29e40: __libc_start_main + 0x80 (c.so.6)
0x1b649: _start + 0x29 (quartus_map)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Ubuntu 22.04.4
OS version: 22
Quartus Prime Information
Address bits: 64
Version: 23.1std.0
Build: 991
Edition: Lite Edition
mem.vhd file:
LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.numeric_std.all;
ENTITY MEM IS
GENERIC(
word_size: integer := 8;
addr_size: integer := 10
PORT (
CLK, RST, CS, WR, RD: IN std_logic;
DATA_IN: IN std_logic_vector(word_size-1 DOWNTO 0);
ADDR: IN std_logic_vector(addr_size-1 DOWNTO 0);
DATA_OUT: OUT std_logic_vector(word_size-1 DOWNTO 0)
END MEM;
ARCHITECTURE behavioral OF MEM is
TYPE reg_type IS ARRAY (0 to 1023) OF std_logic_vector(word_size-1 DOWNTO 0);
SIGNAL reg_file: reg_type;
BEGIN
PROCESS(CLK, CS, RD, ADDR, reg_file)
BEGIN
IF (rising_edge(CLK)) THEN
IF (RST = '0') THEN
reg_file(0 to (2**addr_size)-1) <= (others => (others => '0'));
ELSIF (CS = '1' AND WR = '1') THEN
reg_file(to_integer(unsigned(ADDR))) <= DATA_IN;
END IF;
END IF;
IF (CS = '1' AND RD = '1') THEN
DATA_OUT <= reg_file(to_integer(unsigned(ADDR)));
ELSE
DATA_OUT <= (others => 'Z');
END IF;
END PROCESS;
END behavioral;
