8 years ago
Quartus Prime Lite - Difficulties with simulation
Hi all,
I am trying to figure out what I am doing wrong with simulations involving Altera IP.... Below is my incredibly simple design to show off the issue I am having. I pipe a clock into a PLL generated through the wizard, and watch the clock and locked outputs.
As you can see from the simulation the lock remains low, and the clock output is in an unknown state. I don't see any warnings or errors in modelsim.
Any help would be greatly appreciated.
library ieee;
use ieee.std_logic_1164.all;
entity top is
    port
        inclk0        : in std_logic;
        c0    : out std_logic;
        locked        : out std_logic
end entity;
architecture rtl of top is
    component pll0
        PORT
            inclk0        : IN STD_LOGIC  := '0';
            c0        : OUT STD_LOGIC ;
            locked        : OUT STD_LOGIC
    end component;
begin
    pll0_inst : pll0 PORT MAP (
            inclk0     => inclk0,
            c0     => c0,
            locked     => locked
end rtl;
https://alteraforum.com/forum/attachment.php?attachmentid=14807&stc=1
    Those threads do not appear to have solutions.
    What is the name of the script that is generated during the design?
    I believe modelsim is running this script (simulation/modelsim/robot_board_test_run_msim_rtl_vhdl.do):
    transcript on
    if ! {
    	file mkdir robot_board_test_iputf_libs
    if {} {
    	vdel -lib rtl_work -all
    vlib rtl_work
    vmap work rtl_work
    # ##### Libraries for IPUTF cores
    vlib robot_board_test_iputf_libs/control_internal
    vmap control_internal ./robot_board_test_iputf_libs/control_internal
    vlib robot_board_test_iputf_libs/modular_adc_0
    vmap modular_adc_0 ./robot_board_test_iputf_libs/modular_adc_0
    # ##### End libraries for IPUTF cores
    # ##### MIF file copy and HDL compilation commands for IPUTF cores
    vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/altera_modular_adc_control.v"             -work control_internal
    vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/altera_modular_adc_control_avrg_fifo.v"   -work control_internal
    vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/altera_modular_adc_control_fsm.v"         -work control_internal
    vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/chsel_code_converter_sw_to_hw.v"          -work control_internal
    vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/fiftyfivenm_adcblock_primitive_wrapper.v" -work control_internal
    vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/fiftyfivenm_adcblock_top_wrapper.v"       -work control_internal
    vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/adc_core_modular_adc_0.v"                 -work modular_adc_0
    vcom "/home/swinchen/quartus/robot_board_test/adc_core/simulation/adc_core.vhd"
    vlog -vlog01compat -work work +incdir+/home/swinchen/quartus/robot_board_test/db {/home/swinchen/quartus/robot_board_test/db/pll_altpll.v}
    vcom -93 -work work {/home/swinchen/quartus/robot_board_test/slave_spi_interface.vhd}
    vcom -93 -work work {/home/swinchen/quartus/robot_board_test/robot_board.vhd}
    vcom -93 -work work {/home/swinchen/quartus/robot_board_test/adc_controller.vhd}
    vcom -93 -work work {/home/swinchen/quartus/robot_board_test/pll.vhd}
    vcom -93 -work work {/home/swinchen/quartus/robot_board_test/robot_board_tb.vhd}
    vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm -L fiftyfivenm_ver -L rtl_work -L work -L control_internal -L modular_adc_0 -voptargs="+acc"  robot_board_tb
    do /home/swinchen/quartus/robot_board_test/adc_core/simulation/mentor/msim_setup.tcl
    Are you saying that the msim_setup.tcl should be executed first?
    May be because of compilation order,component interface declaration.
    If you compile each file separately and you have to compile from the bottom up.
    or
    Use script to setup environment which is generated during design.
    Threads addressing same issue
    http://www.alteraforum.com/forum/showthread.php?t=36720
    https://www.alteraforum.com/forum/showthread.php?t=53077
    Anand Raj Shankar
    I tried including the "modular_adc_0" library and get this:
    #  Loading modular_adc_0.adc_core_modular_adc_0
    #  ** Error: (vsim-3033) /home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/adc_core_modular_adc_0.v(26): Instantiation of 'adc_core_modular_adc_0_control_internal' failed. The design unit was not found.
    #     Time: 0 ps  Iteration: 0  Instance: /robot_board_tb/dut/adc_inst/modular_adc_0 File: /home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/adc_core_modular_adc_0.v
    #          Searched libraries:
    #              /home/swinchen/quartus/robot_board_test/simulation/modelsim/robot_board_test_iputf_libs/modular_adc_0
    #              /home/swinchen/quartus/robot_board_test/simulation/modelsim/rtl_work
    #  Loading work.slave_spi_interface(rtl)
    #  Error loading design
    #  End time: 10:57:09 on Feb 09,2018, Elapsed time: 0:00:00
    #  Errors: 1, Warnings: 0
    I got past the PLL issue
    My problem now is with the modular adc simulation. I used the wizard to configure the ADC, include the .qip and .sip files in the project as suggested by the prompt. When I go to simulate I get this:
    vcom -reportprogress 300 -work work /home/swinchen/quartus/robot_board_test/robot_board_tb.vhd#  Model Technology ModelSim - Intel FPGA Edition vcom 10.5b Compiler 2016.10 Oct  5 2016#  Start time: 10:25:41 on Feb 09,2018#  vcom -reportprogress 300 -work work /home/swinchen/quartus/robot_board_test/robot_board_tb.vhd #  -- Loading package STANDARD#  -- Loading package TEXTIO#  -- Loading package std_logic_1164#  -- Loading package NUMERIC_STD#  -- Compiling entity robot_board_tb#  -- Compiling architecture rtl of robot_board_tb#  End time: 10:25:41 on Feb 09,2018, Elapsed time: 0:00:00#  Errors: 0, Warnings: 0
    vsim work.robot_board_tb#  vsim work.robot_board_tb #  Start time: 10:25:50 on Feb 09,2018#  Loading std.standard#  Loading std.textio(body)#  Loading ieee.std_logic_1164(body)#  Loading ieee.numeric_std(body)#  Loading work.robot_board_tb(rtl)#  Loading altera_mf.altera_mf_components#  Loading work.robot_board(rtl)#  Loading ieee.std_logic_arith(body)#  Loading ieee.std_logic_unsigned(body)#  Loading altera_mf.altera_common_conversion(body)#  Loading altera_mf.altera_device_families(body)#  Loading altera_mf.altsyncram(translated)#  Loading work.pll(syn)#  Loading altera_mf.mf_pllpack(body)#  Loading altera_mf.altpll(behavior)#  Loading altera_mf.mf_cycloneiii_pll(vital_pll)#  Loading altera_mf.mf_cda_mn_cntr(behave)#  Loading altera_mf.mf_cda_scale_cntr(behave)#  Loading work.adc_controller(rtl)#  Loading work.adc_core(rtl)#  ** Warning: (vsim-3473) Component instance "modular_adc_0 : adc_core_modular_adc_0" is not bound.#     Time: 0 ps  Iteration: 0  Instance: /robot_board_tb/dut/adc_inst File: /home/swinchen/quartus/robot_board_test/adc_core/simulation/adc_core.vhd#  Loading work.slave_spi_interface(rtl)#  ** Warning: Design size of 17430 statements exceeds ModelSim-Intel FPGA Starter Edition recommended capacity.#  Expect performance to be adversely affected.#  ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/command_ready, and its initial value is not used.#  Therefore, simulation behavior may occur that is not in compliance with#  the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/command_ready.#  ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/response_valid, and its initial value is not used.#  Therefore, simulation behavior may occur that is not in compliance with#  the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/adc_ram_wr_en.#  ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/response_channel(4), and its initial value is not used.#  Therefore, simulation behavior may occur that is not in compliance with#  the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/adc_ram_wr_chsel(4).#  ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/response_channel(3 downto 0), and its initial value is not used.#  Therefore, simulation behavior may occur that is not in compliance with#  the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/adc_ram_wr_chsel(3 downto 0).#  ** Warning: (vsim-8684) No drivers exist on out port /robot_board_tb/dut/adc_inst/response_data, and its initial value is not used.#  Therefore, simulation behavior may occur that is not in compliance with#  the VHDL standard as the initial values come from the base signal /robot_board_tb/dut/adc_ram_wr_data.
    I am not sure how to get rid of the
    Any suggestions?
    Are you using testbench?
    Can you attach the transcript of Modelsim?
    Anand Raj Shankar
    Can you even synthesize the design in Quartus? Perhaps the PLL IP was not generated correctly or you didn't generate simulation model files. Did you make sure that the simulation model is getting compiled in ModelSim?
