8 years agoQuartus Prime Lite - Difficulties with simulation
Hi all, I am trying to figure out what I am doing wrong with simulations involving Altera IP.... Below is my incredibly simple design to show off the issue I am having. I pipe a clock into a PL...
8 years agoThose threads do not appear to have solutions.
What is the name of the script that is generated during the design? I believe modelsim is running this script (simulation/modelsim/robot_board_test_run_msim_rtl_vhdl.do):
transcript on
if ! {
file mkdir robot_board_test_iputf_libs
if {} {
vdel -lib rtl_work -all
vlib rtl_work
vmap work rtl_work
# ##### Libraries for IPUTF cores
vlib robot_board_test_iputf_libs/control_internal
vmap control_internal ./robot_board_test_iputf_libs/control_internal
vlib robot_board_test_iputf_libs/modular_adc_0
vmap modular_adc_0 ./robot_board_test_iputf_libs/modular_adc_0
# ##### End libraries for IPUTF cores
# ##### MIF file copy and HDL compilation commands for IPUTF cores
vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/altera_modular_adc_control.v" -work control_internal
vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/altera_modular_adc_control_avrg_fifo.v" -work control_internal
vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/altera_modular_adc_control_fsm.v" -work control_internal
vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/chsel_code_converter_sw_to_hw.v" -work control_internal
vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/fiftyfivenm_adcblock_primitive_wrapper.v" -work control_internal
vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/fiftyfivenm_adcblock_top_wrapper.v" -work control_internal
vlog "/home/swinchen/quartus/robot_board_test/adc_core/simulation/submodules/adc_core_modular_adc_0.v" -work modular_adc_0
vcom "/home/swinchen/quartus/robot_board_test/adc_core/simulation/adc_core.vhd"
vlog -vlog01compat -work work +incdir+/home/swinchen/quartus/robot_board_test/db {/home/swinchen/quartus/robot_board_test/db/pll_altpll.v}
vcom -93 -work work {/home/swinchen/quartus/robot_board_test/slave_spi_interface.vhd}
vcom -93 -work work {/home/swinchen/quartus/robot_board_test/robot_board.vhd}
vcom -93 -work work {/home/swinchen/quartus/robot_board_test/adc_controller.vhd}
vcom -93 -work work {/home/swinchen/quartus/robot_board_test/pll.vhd}
vcom -93 -work work {/home/swinchen/quartus/robot_board_test/robot_board_tb.vhd}
vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm -L fiftyfivenm_ver -L rtl_work -L work -L control_internal -L modular_adc_0 -voptargs="+acc" robot_board_tb
do /home/swinchen/quartus/robot_board_test/adc_core/simulation/mentor/msim_setup.tcl
Are you saying that the msim_setup.tcl should be executed first?
