8 years agoQuartus Prime Lite - Difficulties with simulation
Hi all, I am trying to figure out what I am doing wrong with simulations involving Altera IP.... Below is my incredibly simple design to show off the issue I am having. I pipe a clock into a PL...
8 years agoHi,
May be because of compilation order,component interface declaration. If you compile each file separately and you have to compile from the bottom up. or Use script to setup environment which is generated during design. Threads addressing same issue http://www.alteraforum.com/forum/showthread.php?t=36720 https://www.alteraforum.com/forum/showthread.php?t=53077 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
