17 years agoQuartus JTAG Programming Issue
Hey guys, I'm using the Max II CPLD (64 macros). After I program (using the Byteblaster II) the chip, Quartus says it finished and verified that the CPLD was programmed. However, when I look...
17 years agoHi,
The signal it was putting out was not what I had expected (and apparently Quartus as well because the simulation came out differently). So I tried loading a hopefully corrected version of the program but I got the same result. I was curious to see if it was actually programming the chip so I just set the output pins to vcc and loaded it onto the chip. The signal it put out afterwards was still the original program I had a couple of weeks ago when it should have been just high. I appreciate the help. Thanks, Joe
