Quartus II that came with my Cyclone II starter development kit has license issue now!
Hi
Welcome to INTEL forum. Based on my understanding, the DevKit license only valid only for 1 year and Devkit license is not renewable.
Alternatively, you could apply an Intel Web License use with Quartus
Here’s the steps:
1. Login to https://licensing.intel.com/
2. Go to Sign up for Evaluation or Free licenses
3. Select Intel® Quartus® II Software SW-QUARTUS-WE-FIX
4. # of Seats is always 1 for Quartus Web Edition
5. Check the T&C box
6. Click Get License button
a. Check the option product “Intel FPGA Software SII-NONVOLENCRYP”
b. Add New Computer or Assign an Existing computer
7. Add the required fields
8. Click Generate License
You will be taken to the Licensing page, and you should be able to receive the email with license attached.
- Ross213 years ago
Thank you! I used this method and it solved my license issue with Quartus. However, once I try to run the simulation via Modelsim-Altera, I get the following errors:
Unable to checkout license. Check Environment Variable and etc...
I attached it as a screenshot.
I set the license I got for Quartus as the license file in both windows environment variables, and lmtools (in Modelsim folder for setting license), but it does not work. It still gives me the same errors.
- Does the same license I got for Quartus work for Modelsim-Altera too?
- Does Modelsim-Altera have a standalone Web Edition (free version) that I can download and install if I cannot solve it using above method?
Please kindly help with this issue as well. Hope it would be the last one to solve to get the entire package work.
