12 years agoQuartus II not compiling
When I try to start compilation or start analysis & synthesis nothing happens. The compilation report comes up immediately and the Flow status says successful, but the date is wrong. I can even ...
12 years agoIt sounds like the files being used by synthesis are not the files you are updated, and so it's thinking there are no changes.
When you setup the Modelsim project did you move the location of the source files??? If that is not the case, my only guess is it's thinking there's no changes. You can try deleting the incremental_db and db directories from the synthesis directory and see if that fixes the problem. Pete
