15 years ago
Quartus II Cyclone IV DDR2_SDRAM PIN problem
Hi all,
I am trying to use SOPC_Builder to build my NIOS system. But after the NIOS symbol is generated, I find that some pins which I can't find out in the datasheet of DDR2 SDRAM. So how to assign these pins correctly?
The following is the pins which does not exist,
DDR2_SDRAM_aux_full_rate_clk_out
DDR2_SDRAM_sux_half_clk_out
DDR2_SDRAM_phy_clk_out
Local_init_done_from_the_DDR2_SDRAM
Local_refresh_ack_from_the_DDR2_SDRAM
Local_wdata_req_from_the_DDR2_SDRAM
Reset_phy_clk_n_from_the_DDR2_SDRAM
Here is the hardware, software, nios2 system I used
Quartus II version 9.1 SP2 full version
Cyclone IV E: EP4CE15F17C7
Nios2 system:
CPU(clk : External clk =100MHz)
EPCS Serial Flash Controller(clk : External clk = 100MHz)
DDR2_SDRAM (64MB,8bit wide, Discrete Device, CAS 5.0, 1 Chip Select,
the parameters was Modified form Micron MT47H64M8CB-3)
PIO(clk : External clk = 100MHz)
sysid (clk : External clk = 100Mhz)
Can anyone help me to solve my problem, Thanks!!!
    I have the same problem, who can give me some good suggestions? Thank you !
    I have spent much time to solve this problem,but i still don't know how to assign pins
