YigalB1
1 year agoQuartus: How to debug why Synthesis is eliminating logic from the design
The Synthesis eliminated large parts of my design. There was a warning about few logic signals that they are not driving any logic, although to me it looks like the RTL is OK. I tried a workaround ...
- 1 year ago
basically unexpected removal of logic suggests a design error, may be wrong logic condition, missing clock or part of the design unintenionally held in reset.
Problem is, if a complete logic chain is removed in synthesis, it's not easy to see where it's broken. Creating auxiliary output or keeping debug signals with respective synthesis attributes (e.g. noprune for registers) and watch them in Signaltap is a possible option. Diagnosis is probably simpler in RTL simulation.
RegardsFrank
sstrell
1 year agoNo, like it says, if you don't connect a signal to anything, it can get optimized away. Use Virtual Pin assignments in the Assignment editor to connect signals to stubs of logic to avoid this.
